Fire fly render
Apr 12, 2022 13:57
Hi thrimanakatha,
Nice cup, thanks for sharing! At first reading just a topic title I was thinking you wanted to report about the fireflies as part of render noise. But that's artistic thing. Btw, have you done your light sources as mesh lights with emissive material or just with omni lights and spherical shape? In case of real geometry + emissive material you may test on/off for importance sampling to get better speed. I think in this case it would be faster with importance sampling = off.
Apr 12, 2022 15:15
Added additional light inside the jar. Random colors to the fire flies.
Apr 12, 2022 18:14
Yes, the enabled improtance sampling will certainly increase the render time but in many cases, especially when the light source shape is very complex geometry and it is has global lighting influence on the scene then it would generate much less noise but with more costly render iterations.
Nov 1, 2022 07:58
Hello author, I found the renderer you developed in China, I feel that the content is really good, I found that there is a lack of emissive material nodes, the rendering speed is not bad, how long do you need to update the emitting material nodes?
Nov 1, 2022 08:04
Tell me if you update, can you record another video tutorial, I will promote it for you in China, and the color mode hopes to add aces options.
Nov 1, 2022 12:02
Have you seen Emissive material node? It can be combined with any other reflective node using mixing material nodes. You may also tune the emissive color for various layers such as reflective, diffuse, direct or indirect lighting. After that I will translate CentiLeo interface for C4D to Chinese, hope you will check it
Nov 2, 2022 09:54
我非常期待新产品的退出,也非常感谢大家对美术工作的贡献,森蒂略渲染器前途无量,振作起来。
Nov 3, 2022 00:47
Well, thank you for the introduction I have found the glow in the node, I would also like to consult, random distribution, renderer label recognition spline, atmosphere, volume, any new news
Nov 3, 2022 09:59
How can I invest in you in China and help you with your work?
Users browsing this topic (9 guests)
