I have centileo set as my renderer, I have everything ready to go, but I cannot figure this out.
Is it the "Render to Picture Viewer" button? That does render my image, but it takes quite a long time.
I am using a 3080Ti, and my resolution is only 1080p.
I used a CPU render engine before this, and it took much less time and even at 4K with much more objects to render.
I uploaded a sample frame; should this take 2 minutes to render?
Does centileo have a special render menu within the IPR or does it use the built-in picture viewer render for C4D?
And if this is the way to render, how do you make it save each frame automatically as it renders them? Mine do not save to the folder I set after each frame renders.
