I cannot find the motion blur option anywhere in the render settings.
all I can find is motion blur settings in the object tag for centileo, however, it is not clear how it works, and adding the tag did not give me motion blur.
I have a helicopter I want the blades to have blur from the animation I give them.
How to get motion blur for render?
1) In render settings you should select CentiLeo renderer. These settings have several tabs, one of them is Camera tab which has what you are looking for. Keep in mind that transformation motion steps implement the motion blur of moving object transform matrices (move, scale, rotate). Keep in mind that transformation step can be set up to 32 and this will work for Picture Viewer renders, but in IPR render the transformation steps will be limited to up to 4 steps for performance.
2) While deformation blur in the same Camera settings tab implements deforming vertex coordinates inside object with constant number of polygons. 3) Also if you have varying polycount of dynamic object then there is a Centileo object tag that you find. This tag has slots to connect with motion vectors (other object tags) if simulation software supplies these motion vectors. These vectors allow to implement deformation motion blur for varying polycount. Such as here
Thank you. I did not think to check the camera menu.
It's camera effect btw
