Can i rotate hdr pictures?
Blender can use nodes to control the environment, CentiLeo for Cinema 4D Support it?Thanks
At present, I can rotate the view to get the light change, but if I lock the camera perspective, can we still rotate or zoom to change the hdr?
Thanks
图像 1.png (636.43 Kb)
Administrator  Posts: 953
Dec 23, 2021 06:39
Sure you can. In Cinema to do this you have to rotate the Sky object that implements the HDR image. For CentiLeo renderer the Sky object of Cinema should add CentiLeo Environment tag, and inside this tag you will see the file link control to HDR file.
Is it the circled label? Which option is used to control the rotation, I did not find it.
I know the purple circled control button is fine, but this is to rotate the camera perspective.
图像 2.png (212.17 Kb)
Dec 23, 2021 07:50
Not this one. There are native coordinates of native Sky object. They have offset, scale and rotation of sky object. They work same way as in any other Cinema object
get it,Thanks
