Unwanted effect with de indirect light.
Hi Kirgman.
I recently encountered a problem that I can't find a solution for.
It's an unwanted effect when I use the alpha channel and two surfaces are very close together.
It doesn't create an unwanted shadow. Rather, it creates a bounce of indirect light, creating shadow or light depending on the indirect light value.
I have to adjust the value to make the effect disappear, compromising the lighting I really want.
I've used the Centileo tag on the affected objects, which allows me to avoid them being affected by the GI, but the desired effect isn't achieved.
Best.
Administrator  Posts: 957
Jul 16, 2025 10:36
Hi Jiv! Thanks a lot for bugrep! I think I have fixed it. Need to test more and then will upload it
Thank you, always. For the excellent work you do.
