We now release an update CentiLeo 0.57 for Cinema 4D R16-R20. The new release adds flexible UVW Projection, Transform and Distortion shader nodes in the manner of Cinema R20. UVW nodes add a lot of flexibility in combination with Bitmaps. Also added easy to setu[ Flakes and Scratches shader nodes for procedural imperfections. Improved Random and Triplanar shaders. Added other usefull shaders like Patterns, Layer, Ramp, Curve Map, Remap, Wire, Side. The other shader nodes are also improved.
We will work on the render speed optimizations for the next release.
Download link (site registration required):
Change Log: cntlc4d 0.575 alpha (2019 March 30)
[cntlc4d] Fixed crash at Cinema 4D R20.059 launch for some other events. The older Cinema R20 builds don’t need this fix.
Change Log: cntlc4d 0.574 alpha (2019 March 28)
[cntlc4d] Fixed crash at Cinema 4D R20.059 launch (just updated to the modified C4D SDK). The older Cinema R20 builds don’t need this fix.
Change Log: cntlc4d 0.573 alpha (2019 March 22)
[core] Fixed Windows 10 memory bug which could cause crashes in scenes with a lot of geometry and textures.
[note] A user can remove texture cache files *.mctx because in new version the texture caches of other bugfixed format with names *.cntx will be auto-generated.
Change Log: cntlc4d 0.572 alpha (2019 March 6)
[core] Fixed artifact bug when SSS doesn’t follow motion blur.
[core] Fixed wrong clamping for 16+ bit bitmaps when used for displacement.
[core] Fixed some triplanar mapping artifacts.
[core] Fixed wrong bump mapping over displacement mapping (when bump and displace maps are different).
Change Log: cntlc4d 0.571 alpha (2018 December 20)
[cntlc4d] Fixed focus distance bug on camera object when CentiLeo camera tag is assigned.
Change Log: cntlc4d 0.570 alpha (2018 December 19)
[core] New UVW Projection node supporting up to 4 UVW tags (mesh uv), spherical, cylindrical, cubic, flat, flat side, spatial and XYZ texture mapping coordinates. Texture coordinate system can be further manipulated (offset, scale, rotation) in the same way as Coordinates Tab of Texture Tag or UVW Projection node of Cinema R20. Offset, scale and rotation can be textured. Procedural texture coordinates are currently determined in the Texture Tag space (related to the object where it is assigned).
[core] New UVW Transform node which performs further manipulations on projected texture coordinates in the same way as the similar node of Cinema R20. Supported manipulations are offset, scale, rotation, pivot, rand offset, repetitions - these parameters can be textured.
[core] New Ramp node which can produce different colors based on the grayscale Input Map values and configuration of the Gradient knots. Up to 30 Gradient Knot values can be textured to produce flexible customization for the output.
[cntlc4d] Improved GUI for materials and shaders. E.g. the edit button doesn’t jump down when the shader is unrolled.
[cntlc4d] The Coordinates Tab and projection types of Texture Tag are supported (except of camera based projections).
[cntlc4d] CentiLeo Bitmaps and Environment maps are now collected correctly when the project is saved with the assets.
[cntlc4d] Fixed cloner object parsing issues which produced wrong scenes for CentiLeo.
[cntlc4d] Scene parsing now accounts for Cinema layer visibility changes.
[cntlc4d] Bitmap reset cache button is back.
Dec 19, 2018 15:03
- Apr 18, 2020 21:37
(Update 0.572 with bugfixes)
Dec 20, 2018 13:00
CentiLeo 0.571: Fixed focus distance bug on camera object when CentiLeo camera tag is assigned.
Dec 21, 2018 04:56
Dec 21, 2018 05:08
you may increase the values later in a bitmap shader or by displacement height scale.
Dec 21, 2018 13:30
after some playing with bitmap i fixed it . and why corona haven't this problem
- Dec 21, 2018 13:31
Dec 22, 2018 13:10
Don't worry, I will fix the issue. It happend because I tried to fix some aritifacts with dispalement for 8-bit images where almost white values created displacemnt aliasing. That fix shoudn't be enabled for 16-bit images. Simple
Feb 6, 2019 08:12
First time CentiLeo user here. Congrats on the awesome development so far. So much has happened since I first read about the project a while back. While rendering in the IPR my computer gets very sluggish and unresponsive. Any settings to get around this? My setup is, i7 5960x 3x gtx 980ti 64gb RAM Windows 10 Cheers, |
Feb 6, 2019 14:26
Hi Carl! And welcome here!
One of my development setup is a bit worse, 32GB RAM and 3x 970GTX. It's rarely have sluggy perf in IPR. What kind of scene do you have? Polycounts, textures? Do you use some physical simulators at the same time? It can be the case if you run several programs that use GPU somehow and they cut GPU resources step by step. And then you enter CentiLeo and it takes some resources too. When there are too small resources it may have some problems. For example, when you are in IPR right-click on mouse and see what GPUs are actually running, what percent of total work each GPU is doing (number next to GPU name), and how the GPU memory is arranged (for textures/geometry and rays). Maybe a screenshot may give me some info. One option to fix that is to go to Render Settings -> Tab Hardware Settings. There you may enable/disable the GPUs for your scene. And also you may enable/disable "low priority" mode. For example, try to disable the monitor GPU and leave all others for render. Or try to enable "low priority" for monitor GPU and disable "low priority" for all others. Anyway, there is a big optimization ongoing work for the next 0.58 release. Our internal GPU kernels will become lightweight and faster. This should help a lot not only for general render speed but also for IPR responsiveness. So, stay tuned, in few months there will be an update
Mar 6, 2019 16:39
[core] Fixed artifact bug when SSS doesn’t follow motion blur. [core] Fixed wrong clamping for 16+ bit bitmaps when used for displacement. [core] Fixed some triplanar mapping artifacts. [core] Fixed wrong bump mapping over displacement mapping (when bump and displace maps are different).
Mar 22, 2019 17:15
Mar 27, 2019 20:52
I Cinema 4D R20.059 update and now it does not work
Mar 28, 2019 14:41
May 13, 2019 08:33
Just registered to try this out but can't get either of both versions to work.
EDIT: Nevermind, i'm on a mac.
- Nov 6, 2019 06:54
May 13, 2019 09:16
Yes, Leif! Sorry about that. Mac isn't supported because we are still on CUDA
