Pages: 1 2 Next
RSS
We release CentiLeo 0.55 for 3ds Max with new powerfull displacement mapping engine too!
As said in C4D 055 thread there were many R&D tasks that should be solved to make it working normally.
Our Displacement mapping tech is based on pre-tesselation of geometry before rendering. But it's fast and has good memory economy.
This pre-tesselation approach helps to use arbitrarty shading networks now. And it will allow to extend it to vector displacement mapping in the future.
Currently CentiLeo displacement mapped objects are tesselated very-very quickly and render very fast. Faster than competitor pre-tesselation methods. Potentially hundreds million unique triangles can be handled very efficiently if needed for very high resolution.
Download link (site registration required): http://centileo.com/forum/forum13/150-download-link-centileo-for-3ds-max-v0551-alpha
[cntlmax] Added 3ds max 2019 support.
Change Log: cntlmax 0.552 alpha (2018 June 16)
Change Log: cntlmax 0.551 alpha (2018 June 12)
[core] Support for 16/32 bit bitmaps for Displacement.
[core] Fixed various rare visual bugs, e.g. a bug that made visible artifacts at low FOV.
GPU Drivers
Edited: Kirgman - 28.12.2018 10:41:12 (0.553 3ds max 2019 support and fixed animation crashes with Greeble modifier)
bump
8)
//Daniel
version function for forest pack?
Hi Angelo, this will be available in CentiLeo 0.62 together with other instancing/scattering improvements. In several months :)
Hi is there a way to use maps other than bitmaps as bumpmap? as it is now I cant even put a color correction node on it
//Daniel
Hi Daniel, any map is usable in the bump map. Color correction however corrects the color info in certain range. But internal bump data can have negative numbers and large values which are color corrected in a wrong way. At least avoid using clamp inside color correct node or extend the limits of clamp.
I have changed the bump internals completelly in the new version. And need to make some bump correction node related to this issue
Only 2 wishes: round corner and denoiser :)
Hi Harry, welcome here! Ok, will do that in the future, but not just very soon. Need to work on shaders and some optimizations
OK Semes I have done something wrong then. Now bumpmap works with everything
even hair works now!! :) when did that happend?
//Daniel
except the blend map dont work for bump for some reason?
Well, the hair shouldn't work. We don't yet have spline intersection support. It was just the triangulation of hairs by 3ds max that CentiLeo is ordering. There should be considerably more efforts to make the spline rendering right and that would be cool and much more efficient than triangles.
Will test the bump + blend map and get back to you.
bump + blend in 0.55 no problem when mixed.
However it looks better in 0.56 for C4D :)
OK Thank you. For some reason I didn´t get it to work earlier..
Will there be a way to control dof focus in the next release?
//Daniel
Do you mean animated DoF focus? Right now it works statically but because of bug dousn't record param values on animation. Will fix that by next release together with other big improvements.
Yes right. Animated dof focus.
linked to camera target or even better a just a spinner you can bind to an expression
//Daniel
Edited: Daniel Westlund - 19.09.2018 03:59:05
When will we see an upgrade?
//Daniel
Hi Daniel, some quick news:
There will be centileo 0.57 for Cinema with many (10+) new shaders/textures in around 2 weeks (maybe less). Another super important release 0.58 will come at around the beginning of January. And also for Cinema only.
As for CentiLeo to 3ds Max plugin then the next update will be 0.61 in around half a year since now. After 0.61 both plugin updates (for c4d and max) will come together at the same time. And it will be easier to maintain them. The reason is that I want to develop core CentiLeo features (shaders, procedurals, optimizations) as fast as possible while 3ds max GUI writting is long (but Cinema's is easy and requires almost no time).
0.61 will contain many standard shaders/textures (procedural mappings and noises), attributes support (per vertex, per instance), further improved displacement mapping, geometry scattering, true massive instancing (for particles and etc), better color output (and tonemapping) and faster. It will be a very cool and usable rendering arsenal, better than others.
8)
Nice updates.
Will update CentiLeo for 3ds Max on 0.58 release with new shaders and render speed optimizations.
//Daniel
//Daniel
Hi Daniel, I heard some user tested CentiLeo with RTX 2080 and it was working faster than with older GPUs. But I haven't tested personally, still using 970 and 1070.
As for RTX rays acceleration hardware feature - not supported. At the current state of RTX ray acceleration feature - it may be not compatible with some current and future CentiLeo features.
Btw, I will update CentiLeo for Max at the next 0.58 release :)
Thanks for latest updates.well done :)
Not sure if its the 4k resolution or something else.
Best
Daniel
Thanks, good to know!
//Daniel
Pages: 1 2 Next
