Pages: Prev. 1 2
Nice updates.
Administrator  Posts: 982
Dec 19, 2018 15:09
Dec 28, 2018 10:42
[cntlmax] Added 3ds max 2019 support.
Will update CentiLeo for 3ds Max on 0.58 release with new shaders and render speed optimizations.
//Daniel
Feb 7, 2019 15:51
//Daniel
Hi Daniel, I heard some user tested CentiLeo with RTX 2080 and it was working faster than with older GPUs. But I haven't tested personally, still using 970 and 1070.
As for RTX rays acceleration hardware feature - not supported. At the current state of RTX ray acceleration feature - it may be not compatible with some current and future CentiLeo features.
Btw, I will update CentiLeo for Max at the next 0.58 release :)
Thanks for latest updates.well done :)
Not sure if its the 4k resolution or something else.
Best
Daniel
Feb 22, 2019 05:10
Thanks, good to know!
//Daniel
Mar 20, 2019 11:23
really longing for an update now ;)
//D
Jun 4, 2019 15:40
Great job guys keep up the good work ;)
Pages: Prev. 1 2
