X
You should create and paint a vertex map tag in C4D for your object, then create a vertex map node in node material editor and assign it to any shader property you want.
This was discussed here |
If you don't already know about how to use Fields in amazing ways watch this video by RocketLasso. You can have vertex maps effects grow from a single point or a field and do things like plant growth, and I believe the same principle can apply to materials using vertex maps as well. The fields can also affect dynamics and mograph. |
thx! I have set fields, before I can’t comprehend why the vertexmap node not see the map attribute like redshift node,but now I have done
RS references the vertex map tags from the nodes using the name strings. While we use tag ID in the same way as native C4D nodes that are used for Physical/Standard render
