We finally made CentiLeo 0.48 for Cinema 4D R16-R18! It took so long time, so many efforts. Sorry for very long waiting! We thought were close to release for the last 2.5 months but technical development issues emerged and forced us to do more complex solutions to get right result. And that cycle happened several times. This 0.48 version development was harder than integrating with C4D or 3ds Max .
Download here:
Download shaderball:
User manual from 0.44 (yes it needs update):
Change Log: cntlc4d 0.480 alpha (2017 May 2)
[core] Material editor preview: much faster and nicer preview render. [core] Each GPU is initialized with as much memory as needed by scene (unlike taking all free memory even for trivial scenes in CentiLeo 0.47).
[C4D plugin] Improved render time in native Picture Viewer mode by updating secondary AOV output less frequently.
[C4D plugin] Slight reorganization of Material editor GUI (all SSS are placed in one tab, Translucency is also placed in a separate tab).
Change Log: cntlc4d 0.481 alpha (2017 May 3)
[core] Fixed bug when one of several GPUs may randomly avoid participating in collective rendering
Change Log: cntlc4d 0.482 alpha (2017 May 4)
[core] Fixed bug when changing any Mix parameter of material (or any parameter which has no effect ) may cause render degradation and crash.
[core] Fixed bug when switching between materials (and/or removing them) may cause render stop.
[core] Fixed bug with artifacts related to wrong smooth normals of mesh.
[core] Fixed bug with artifacts on anisotropic reflections.
[core] Fixed bug when material tangent space doesn’t really change when user enables it.
[C4D plugin] Added Sun item to main CentiLeo menu which adds sun with proper tags understandable by CentiLeo.
Change Log: cntlc4d 0.483 alpha (2017 May 10)
[core] Fixed bug with missing polygons on small objects like plane.
[C4D plugin] Fixed bug with render stop upon deletion of material tag.
[C4D plugin] Fixed bug with IPR random wrong parsing of objects and render freezes.
Enjoy rendering with CentiLeo again! And please shader experience related to multi-GPU behavior.
CentiLeo for Cinema 4D 0.483 available (multi-GPU and efficiency improvement)
test description message
May 2, 2017 16:25
- Apr 26, 2020 05:35
(Added info on update 0.483 (May 10, 2017))
May 2, 2017 20:46
0.481 update: Fixed bug when one of several GPUs may randomly avoid participating in collective rendering.
May 2, 2017 21:00
Hi Kirgman! great news buddy!
I'm testing here, thank you! bug report: IPR and cinema freeze when you change from a material to another when IPR is running. |
May 3, 2017 05:05
May 3, 2017 06:43
I got stability problems when changing any kind of Mix parameter in material
May 3, 2017 07:19
Hello Kirgman! Congrads on the release! It is running super fast so far with 7 gpu's 1080's. Couple of things I've noticed:
That's it for now, I will test further and again, congrads! |
May 3, 2017 08:13
Hi Konstantinos! Thanks for the test!
It is interesting to know what are the timings with this scene with 1, 2, 3, 4, 5, 6, 7 GPUs. And with/without display GPU. There are some stability bugs because a lot of things have changed. Trying to fix them asap. We really lack good shaders arsenal. In the next few updates there is a plan to make at least 20 shader nodes, procedural noise and mapping. Also want to make it friendly with TextureTag. I was thinking about 3rd party GUI engine for node editor, but will probably do like xpresso with native c4d tools. To make a sun you should add c4d sun obect + centileo light tag. I will add more presets like sun, glass material to the top menu
May 3, 2017 08:32
Hi Kirg! I will do a step by step video soon
May 3, 2017 08:44
May 3, 2017 13:03
Work fine with 1080ti SLI. I'm testing here, thank you! |
May 3, 2017 15:29
May 3, 2017 16:35
Hi Kirg! thanks for the sss in one tab. much better now!
here the link to the bug video: dual nvidia 970 GTX Request feature: a channel for material alpha(Std Material) it will allow us to use a material stack like we have in Cinema 4D plus: the material tags need to be avaluated from left to righ at object manager see the image:
- May 3, 2017 16:50
May 3, 2017 16:46
Feature Request: add an option on Cinema 4D preferences to set the defaults GPUs for rendering(like this example from redshift)
image: |
May 3, 2017 18:51
Hi Rodrigo! The video is very clear about what is happening. Thanks for your effort!
May 4, 2017 10:35
I do not know if it is the best behavior, other renderers have a global option in Cinema 4D preferences and an option to override globals in the scene options. I think this is the best way to implement it.
Imagine that whenever I create a new scene I will need to adjust which GPUs I will use. This is not good from the point of view of practicality. |
May 4, 2017 11:03
I think similar way already. I have fixed my bug (with Mix param) and your bug. The source of problem was the same funny mistake. I have reproduced the steps from your video and the problem doesn't appear anymore. Currently I am solving a bug with wrong smooth normals and resulting artifacts that appeared in 0.48, Once I fix it there will be small bugfix update. After that will continue working on new features
May 4, 2017 19:52
+ 0.482 update with 5 more bugfixes mentioned here. See first topic
May 4, 2017 21:59
Feedback: 0.482 still freezing in the same case of materials.
nvidia driver 382.05 nvidia gtx 970 nvidia gtx 970 try change the order of materials tags....it happens too.
- May 5, 2017 04:00
May 5, 2017 05:57
Hello again,
Some bugs and requests: In the image below I get this black area that I don't get with other render engines, it must be a bug. If I change the camera during render the ipr does not update, I have to close the ipr and restart it. I figured out the sun but I don't see a real sky model so far, maybe it's in your to do list? If yes then an atmospheric haze or fog option would also be nice! I would like the values for exposure and highlights and all that to be more unlimited than 0-10. The scale could be from -10 to 10 but if we type in bigger or smaller numbers they should have an effect, much like the rest of the sliders in C4D. It would be cool to be moved in a tab in ipr lico corona renderer or vray. Cubic mapping support is a must. Node system for materials... Please don't take all that as negative, I'm just trying to provide feedback for what I think is a very good and promising render engine! Good job so far! |
May 5, 2017 08:17
As for the black artifact on the pillow - I have seen it before in the engine, but then it has gone by itself before I was able to fix it. Please, can you send me the model of this pillow separatelly so I would operate on the problem more productively. Physical Sky model as you describe is in our Todo list. We start improving our shaders and make other graphics features. And there will be handling of material tags list per object same as in native C4D renderers. Later will do node editor. C4D is very pleasant environment for programming, it's really like a pleasure.
