Hi everyone!
CentiLeo 0.54 for Cinema 4D R16-R19 is ready! Quality becomes better! Bump is much better, however the majority of time was spent on glass+liquid correct IOR handling.
Download link (site registration required):
Change Log: cntlc4d 0.541 alpha (2018 January 9)
[core] Fixed bug for CentiLeo in Cinema R19 where animation frames were not recorded.
Change Log: cntlc4d 0.540 alpha (2017 December 18)
[core] Support nested Transmissive refractive objects with different IOR (e.g. liquid in a glass with ice cubes inside). A liquid object geometry must overlap slightly the glass (same as in other modern renderers). The material of liquid object must enable the flag “Is Liquid” (available in cntlMaterial->Transmission menu). Same works with water droplets on the bottle or any other liquid objects that are modeled inside or outside a glass with slight geometry overlapping. This way all relative IORs between refractive mediums will be computed correctly internally.
[core] Added procedural Dirt shader which can enable different colors and material properties on crevices, convex and concave geometry regions. Occluded, Unoccluded and Distance parameters can be textured. Dirt shader can be nested into other Dirt shader.
[core] Fixed bump mapping “terminator” artifacts that can be visible on lowpoly objects and lit by small area light source. User can tune the effect of this fix with “Light Shift” parameter which is available in cntlMaterial->Bump menu for Cinema 4D and in cntlMaterial->Common for 3ds Max. This works for all material properties (diffuse, reflections, etc.).
[core] Fixed reflection artifacts on low poly geometry where smooth normals differ too much from real normals of geometry.
[core] Fixed reflection loss of energy when combined with other material properties such as diffuse or SSS.
[core] Fixed SSS color and weight automatic normalization.
[core] For easy handling in cntlBitmap there is no need to select type of texture “image”, “b/w bump” or “normal map”. This is resolved automatically, except for normal maps where user must enable “Is Normal Map” flag.
[core] Added option “Output Alpha channel” to cntlBitmap. Useful for application with PNG and cntlMaterial->Alpha channel.
Please test and report about any issues in this pack.
    	CentiLeo for Cinema 4D 0.541 available (nested glass objects and liquids, dirt shader, fixed bump mapping)
                                        Jan 8, 2018 13:18
                                 hi guys .
 in r19 when i try render All frames it's just rendering first frame . |
                                        Jan 9, 2018 04:06
                                        Jan 9, 2018 04:54
                                 Aimar, no need for your scene. I have detected a problem in R19. But in R18 everything is ok! Strange thing! I go to fix it.
 Btw, do you use R19 Demo or activated licensed version?
                                        Jan 9, 2018 08:56
                                        Jan 23, 2018 02:39
                                 Just installed your renderer to my plugins folder and cinema crashes when trying to load the plugin. If I remove your folder cinema loads perfectly. C4DR18.
                                        Jan 23, 2018 03:09
                                        Jan 27, 2018 08:21
                                 Hi there, Sorry for the delay. I'm assuming it might be the graphics card? I have an AMD Radeon R9 200. |
                                        Feb 7, 2018 14:55
                                 Hi Guys!
 please add a "About" icon at our Centileo menu that prints the version and other important infos like links for forum, list of fixes... etc... |
                                        Feb 7, 2018 16:51
                                 Noise Shader typo =
 Turbulince correct: Turbulence |
                                        Feb 7, 2018 16:58
                                 Centileo ID tag not working in R19 |
                                        Feb 8, 2018 03:45
                                 Hi Rodrigo,
 As for ID tag - it shouldn't work. It's created for internal storage of some info, not for user. It's a hidden tag, so there is some bug of Cinema that you see it   But there will appear some Object Tag to do more things than that. As for the rest - ok, will do that.
                                        Apr 3, 2018 08:07
                                 Huge fan of Centileo in Cinema 4D, I can't wait to see what comes next! |
                                        Apr 3, 2018 16:46
 There was a lot of R&D done since the begin of the year. Very soon there will be 3 new releases one after another. E.g. the next one will get displacement mapping.
                                        May 28, 2018 09:48
                                 Hello. I've tried it in a small project a month or so ago and it was really stable and with great picture quality already. Not much news here about Centileo development lately. Is it still in progress?
 p.s.: can't get here on site without VPN....
        - May 28, 2018 09:49
                                        May 29, 2018 04:26
                                 Hi Egor! Welcome on our forum! You are right, we need to update the site content better.
 But there was no stop in development because this time we digged too deep in displacement tech internal things. There will be a new release 0.55 in few days. When few other important releases will be done we will be more active on the web.
                                        May 29, 2018 09:51
